crank interchanging
jeffatc250r
crank interchanging
Post by jeffatc250r »
I have a 85 motor in my atc, and am in need of a crank rebuild. I see no aftermarket for this. My question is this, can a newer style crank be dropped in and a spacer plate be used?? This would be great since the newer style cranks are rebuildable with atermarket rod kits and are quite plentiful. Its the case height that is different right?? Any info would be much appreciated.
jeffatc250r
Damn, was hoping someone on here has tried it before.
it probly be cheaper to put a new rod on it. oem, prox, hotrods, vesrah, wiseco.....take your pic which brand. rod is $80-$100 depending where you buy it, and probly $100 for a shop to install it. complete crank is $316+ shiping. cometic will make the spacer, they might even have some already made. check the case studs, they might need to be longer but im not for sure.
nmdesertrider
Post by nmdesertrider »
You can get the OEM short rod from any Honda dealer.
03 CRF450/85 500
how do you order a honda rod ? s/h only shows the whole crankshaft
i had a new one i got 2 months ago, but sold it cuz my 525 needs a long rod :cry:
nmdesertrider
ROD SET, CONNECTING
13200-KA5-690
Look at 85 parts they are broken out--- the old drawings are funny that way
03 CRF450/85 500
OEM Honda short rod, try here rjewell@noyesmotorcycles.com
It's in Australia but if they are hard to get, it might be your only option.
electech
Post by electech »
You can get it in the states, I just went through mine, any Honda Dealer.
jeffatc250r
Thanks guys, did a little bit more research and found a dealer with the rod set, thanks again.
