Right case cover corrosion.
bobbee9
Post by bobbee9 »
I have an 87 CR500. It is "new" to me and had a large leak of coolant into the oil. The 87 right case cover had leperasy from years of corrosion from the coolant (I think?).
The reason for this note: I put on a 2001 right case cover, new impellor and shaft all new from Honda. They are a perfect fit.
I just wanted to share this information. Good luck to all of you. WFO
Bob
Glad you got it back together
I've got more tech stuff linked at the bottom of every post i make
