38mm PWK jetting Help
tooney
Post by tooney »
Hi all,
I am swapping the old PJ from my 1996 CR500 for a slightly more modern PWK 38mm quadvent airstriker and would just like a little advice on the jetting please
The PWK at the moment is set up with,
165RD main
42 pilot
N85C needle
#7 slide
Another long jet with the Keihin star and 85 on it(not sure what this is called sorry)
I was thinking of changing jetting to,
170 main
45 pilot
CGL or CGK needle
#7 slide
The bike is standard at the moment but will be upgrading to a full FMF system soon hopefully
Elevation 0-500 feet
93 octane fuel mixed at 32-1 with maxxima 927
1996 CR500
Thanks in advance
Tooney
Re: 38mm PWK jetting Help
tooney wrote:Hi all,
170 main
45 pilot
CGL or CGK needle
#7 slide
Tooney
Thats a good place to start. Don't need to worry about the slide #. I've never seen anyone have an issue with that.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
tooney
Post by tooney »
Thanks,
I'll give it a try and see how we go on.
bearorso
Post by bearorso »
I run:
170 MJ
1469 Needle
35 PJ
#6 Slide.
Zip Ty air screw with a small tab stuck in the screw drive slot, Stainless Idle screw with butterfly nut head - these allow me to know by feel where they are set. I adjust these more than any other part of the carb.
Std Pipe, Long Mufflers, My own porting. (this consists of transfer & inlet mods , nothing major - CREs are real Friday afternoon bikes - I had a marble sized chunk of alloy in the LH inlet transfer boost port!) I also run a 6.6mm reed block spacer - not for more crank case volume, but because I feel the reed block shrouds both the transfer boost ports & the barrel upper inlet boost port.
With the richer slide, I could go to an even leaner pilot probably, the bike starts & idles perfectly, with perfect response off idle - great for all the tight stuff I ride on. Iggys right though, with a #7 slide & bigger PJ they work well. With 13 series needle it pings under load from mid up, as it does with leaner than 1469 needles. I'm tempted to try one of the SLP inlet devices, if only because @$49.00, it's a more realistic price than all of the other types out there.
robertg
Post by robertg »
35 pilot jet? I didn't think they make one that small.
i've got
#7 slide
50 pilot
dgn@4th clip
178 main
needs more pilot below 20c
i blued the pipe with
#6 slide
48 pilot
dgn@4th clip
175 main
tooney
Post by tooney »
Roostius_Maximus,do you think your jetting would suit my elevation 0-500 ft?
i put a 35, cgl, 170 in mine today, going to ride it tomorow and see what it does. was a 38, n85c,172, 6 slide.
tooney
Post by tooney »
100hp Honda
How was it with the N85c needle???,
is yours a 38 or 39 mm
not bad but im higher elevation. around sealevel it would probly be better. mines 38mm. i didnt get to run the bike with the new setup, hopefully tomorow.
