$200 1986 cr500
- kelroy_leon
$200 1986 cr500
i just picked up an 86' cr500 that is really clean! ill get pics up soon but im looking for some older parts that might be in someones garage. im looking for some old acerbis grey fork protectors and the front master cyl guard.
- kelroy_leon
water pump
i will try and get pics up later but at the moment i have a question. the water pump housing portion of my side case is swiss cheesed on the 86. cant i just run one of my 90 side covers for now? i have an extra 90 engine that i could take parts off of. that would let me run the larger clutch pack right? i may have to modify my rear brake lever a bit. would a 90 cr 250 side case be the same as a 90 500? would that one work on my 86? other than this issue, some new sneakers were the only thing the bike needed. thanks for any info
- kelroy_leon
86' 500
i have all the factory plastics and the original seat in great shape. id love to keep it true 86' but the 86' side cover is a bit to much $$$ for me right now. i still have had no luck finding grey acerbis fork guards.[/img]
- CR500R7
Use your 90 cover, just clearance issue with brake pedal.
Maybe clearance with hose and exhaust.
- NightBiker07
you picked up a CR500 for 200 bucks?!!
you cant find those bikes around here hardly ever, and there always at LEAST 1500 bucks
- Wheelie-Gene
Re: 86' 500
I have an early cover. I'll have to see what shape it's in.kelroy_leon wrote:[/img]
Any chance you'd swap it for a later 2-piece???
2nd gen SSS street hooligan
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
- kelroy_leon
sent a p/m. its getting closer by the day. i have been tracking down some oe parts like levers, springs little stuff. i had been trying to find gold renthal cr high bars but had no luck. went with a set of tag bars instead. havent used that brand before. also been looking for some 86' team honda pics to see what sponsor stickers they were running back then, could anyone give me a hand with that ? i would love to run a disc on the back and make more of a david bailey bike out of it. also, if anyone has an old white acerbis cable guide and would like to part with it let me know.
thanks
thanks
- kelroy_leon
just got in from trying something out. as i was sitting on the 86' it felt a bit cramped even with the cr high bends. my brother told me about an old article in wich they swapped the top tripple clamp with one from an 86' cr 125. it gives me about 7/8" stretch plus a little more height. they did the pegs as well. so the tripple is done and i will get the pegs on tomorrow. should be an inch lower and an inch to the rear. i think this combo will work out great for me since im not the shortest or smallest of persons.
- kelroy_leon
a little bit of an update. i found a place on the east coast the had 2 1986 cr500 crank case covers in stock. the price was fair so i ordered one on the spot. the 2 case were at a honda parts place is iowa i think. i tell the guy that i would like one since there is only 2 left anywhere. ok, all set he tells me, this must be your lucky day
. thats what i thought, all was going well so one day i called them and asked out of curiousity about the shipping on my order. the best part is, that in the time between calls i had called just to confirm, pn 11340-ka5-690 correct ? yep, thats what it is he tells me. well it looks as if the item you have on order is no longer available ???? um, but you confirmed my order and it was in stock ? twice even ?? oh, um, when did you call me and order it ? the 21st... oh,..... well i didnt process the orderrrrrr... "slightly muffled" until the 27th. if any of you have been in this type of situation, im sure you know how i was ready to react... no need to bore you with the remaining details. the current fix will be: 1990 cr500 cover, take a brake pedal off of the 86 cr125 donor so i can avoid the clearance issues and not mess up the original 500 parts and last, go to my local auto zone and have the guy look at me like im an idiot when i tell him i need to look at heater hoses. what kind of car? no car, a bike. a bike ? what bike has a heater ? are you kidding me ?
- CR500R7
kelroy_leon wrote: go to my local auto zone and have the guy look at me like im an idiot when i tell him i need to look at heater hoses. what kind of car? no car, a bike. a bike ? what bike has a heater ? are you kidding me ?
I hope you didn't take the time to explain it to him.
I had the exact same problem. Ifact the last time I went looking for some bent heater hose (gen-4) I just walked right into the back where the hoses are and when the guy approached me I said "its cool man, I'm just looking for a hose"
he didn't know what to say, so he just said "okay"
- CR500R7
dannygraves wrote:I had the exact same problem. Ifact the last time I went looking for some bent heater hose (gen-4) I just walked right into the back where the hoses are and when the guy approached me I said "its cool man, I'm just looking for a hose"![]()
Now, why doesn't this surprise me.
Sometimes the only way to get something done properly, is to do it yourself.
It is also quicker with less stress.
- kelroy_leon
update,
put the 90' cover on my 86'. brake pedal clears but the pipe had been tweaked. it needed a little help but it wasnt too bad. a clean straight pipe should clear, might need just a little help. does anyone have a 85'-88' pipe out there ? other than some minor tlc and some new sneakers it hasnt needed much. im still looking for a 85'-87' front number plate, can someone help me out ?
Lookin sweet! Makes me miss my old '86... But I sold it to my buddy, so I still get to ride it from time to time... Are you still lookin for more parts? He has a small stockpile of spares, so I can see what he would be willing to part with. Also one little trick goodie I did before I sold it was too put '01 500 stock pegs on it. Made a huge difference, and If I remember right it didn't take much to get them to fit. Oh and I think I had to drill a new hole for the return spring. I got a pic of the "mod" around here somewhere, I'll try to find it for ya!
Keep it up man, that bike is a ton 'o fun!
-Brad-
2001 CR500 Steelie
1999 FXSTB Custom
2004 BMW X5
1994 Ranger Prerunner
1999 XR70
2001 CR500 Steelie
1999 FXSTB Custom
2004 BMW X5
1999 XR70
- CR500R7
If the mount on the frame is the same as an 88 CR500, the pegs will fit without any mods. ( 01 CR500 pegs that is. )
RideRed
That's soo true!CR500R7 wrote:kelroy_leon wrote: go to my local auto zone and have the guy look at me like im an idiot when i tell him i need to look at heater hoses. what kind of car? no car, a bike. a bike ? what bike has a heater ? are you kidding me ?
I hope you didn't take the time to explain it to him.![]()
I find it funny when you go into the auto parts store and ask for something simple like a air filter or a heater core, and they always ask if it's a 4x4...
I say: "No, those are always $20.00 more." The smarter guys get mad, and the simple ones agree with me, without question!
BTW: Great score on the CR500!!! Restore it or make it an AF, but don't leave it be...
- ScooterCR500
Re: 86' 500
I had the very same thing occur on my 85. Oil seal leaks and mixes with anit-freeze and makes some type of "aluminum eater" liquid. I bought a new side case 200 bones...dang..kelroy_leon wrote:[/img]
i used 1999 250 pegs on my 87 500 with a pin swap
- kelroy_leon
- Wheelie-Gene
- kelroy_leon
- kelroy_leon
Today I am going to try and fit some gen 1 pegs on the 86'. I have the front end off of the 85' currently. I may just run my set of 87' showas on it for now. Does anyone out there have a decent 85' seat that they want to part with ?
