all motor bearings , from mains to selector drum to water pump .
ta in advance
oggo
i was going to get SKF for motor bearings , i will order the retaining lip from honda irelandRoostius_Maximus wrote:the only bearing in the trans thats special is the one at the sprocket side with the retaining lip, it can be cut in a standard bearing, but is cheaper to buy oem than labor.
I'd buy oem crank bearings, or allballs
