Moose E-Z pull clutch unit
- dahondaboy
I bought this on a clearance deal for 20 bucks. its the mosse ez pull clutch thingy its triangle shaped and has three settings . i first set it to the easiest position but found it gave no feel as to clutch engagement although i could use one finger to use the clutch , i did not like having a dead response in the lever. i moved it to the middle setting and i like it alot, it has some response and makes feathering the clutch very easy. i can use 2 fingers all day and not get pumped up arm. very worth it if its on sale.
