Needle jet help
Needle jet help
I've got a momentary blubber when I hammer the throttle, as it comes up thru the rpm's. I'm guessing that its because I'm too on the needle. I've got a R1368M on the 4th clip installed right now. On hand I have a CGK, CGG, and a R1368N. Which needle/clip should I use to eliminate that? Track time is really limited otherwise I'd just start playing. Thanks in advance...
Carb is a PJ, bored to 41mm with a wing deal in it, and a K&N filter. Cr500, ported for top end, 89.5 bore, nikasiled. I'm in Iowa, about 800ft. Running C12 mixed 32:1 with Green Label Blendzall. CR250 Ignition.
Once it gets past the bog it runs like a mofo... just looking for a little better throttle response.
- kanecr50094
