case saver
aloha450x
case saver
Post by aloha450x »
I bought the stock saver off bikebandit. I was unaware that it is aluminum. where can I get a trick steel one? I don't have much faith in .70 aluminum and its ugly to boot. what are my options.
aloha450x
Post by aloha450x »
I'm looking to get a new throttle too. which one should I get? I was looking at motion pro but don't know which one. and cable. thanks guys
aloha450x
Post by aloha450x »
will this work ok? http://cgi.ebay.com/PRO-TAPER-THROTTLE- ... dZViewItem
nevermind check part numbers and it will work. oh yeah and the cables are the same too.
if your chain is always adjusted right, its almost impossible for it to come off. and a cr5 doesnt have enough power to break a GOOD chain. me, lewisclan, slomas, Pstoffers are all using about 8ft of chain: i cant speak for those guys but mine has never popped off. i think your paraniod dude :lol:
aloha450x
Post by aloha450x »
true. i have only seen one chain snap and he never took care of it. it flew right out of the back. would hate to change cases due to a 20 dollar part.
Nodge
Post by Nodge »
I have busted 2 chains on sport bikes, and once on a Cr250 I lost a master link.
The first time I lost one it ripped the chain guards right off, and a small chunk of the case with it. (just the part that the chain guard bolted to.)
A good sized chunk of the subframe saw some rash as well.
It also chucked the chain into the air and then went twirling town the highway at about 6 other bikes behind me.
Second time it just spit the chain straight down onto the road and didn't damage anything at all.
On the Cr250 it got stuck in the chain guide and then wrapped up in the rear wheel.
Fun fun fun!
patgas
Post by patgas »
i had one go on a crf450 whilst going full tilt up a widiwmaker,it whent through ignition cover and smashed crank case ,very expensive
aloha450x
Post by aloha450x »
so where can I get a nice steel one?
agent
Post by agent »
I am interested in a steel one as well ............... Anyone?
can the crf ones be adapted?
Rick :?:
nmdesertrider
Post by nmdesertrider »
Had a guy at a race a month ago have a rock get dragged into the case saver. It totally destroyed his yz250- needed new case + tranny
03 CRF450/85 500
A steel case saver is only as strong as the bolts that hold it on. :wink:
case saver OEM
throttle tube OEM
You dont want a steel case saver.
The aluminum one is meant to be sacrificial.... the steel one is going to tear....shit.......up.
south central hoon
Post by south central hoon »
AlisoBob wrote:You dont want a steel case saver.
Myself alisobob and mfdb had a discussion about case savers on saturday night.. if you buy a case saver that is harder than the material its bolted too your gonna rip apart the case no doubt. Just stick with an OEM case saver and call it even.. that was the saver breaks and not your case.
90cr500guy
Post by 90cr500guy »
When I first bought my '90 cr500 it didnt have a case saver.
Turns out that the chain had taken out the saver, and case. The threaded boss the saver was bolted to was broke out and the clutch cam area had been welded up. Thats not to say the chain wasnt thrown 2x, once with and once w/o the case saver. I have no way of knowing. The only thing that I do know about the bike is that it had had a hard previous life.
Brit's queer
If I remember correctly, DeWayne makes case savers that bolt onto the oem spot, buy extends further out to stop the chain from bunching up.
if you can keep the chain from bunch up, it'll just go out the bottom and end up on the ground. the OEM case savers are really short, so there isn't really enough to keep the chain from bunching up, getting jammed in ther and breaking off the bosses the case saver bolts to.
MrDude_1
Post by MrDude_1 »
TYSTYX wrote:A steel case saver is only as strong as the bolts that hold it on. :wink:
you mean.. as good as the sheer strength of the bolt... and that should be significant..
anyway.. after breaking a maintained chain on a HawkGT.. ive determined that chain fate is determined by motorcycle gods, and thus, breakage must always be assumed to be a possibility.
90cr500guy
No the weakness is not the bolt, but rather the aluminum the bolt threads into
Brit's queer
ive never heard of, nor seen photos of a good qaulity chain break in half :?. i dont see it physically possible for cr500 to break 9,000lb strength chain
my guess of what happens:
1- masterlink improperly installed
2- chain too loose and it jumps ship
I run DID gold x-rings on all of my bikes and have never had a chain break... *knock-knock
Travis
Post by Travis »
I have never saw a chain break either. Most I see stretch then get thrown off. Then they bunch up and break shit. I had one roll off on my 86 lt 250r. When it bunched up it got so bound up that it broke the case saver off and then wadded between the gear, shifter, and case that it broke my sproket. It jumped at WFO. :shock: Anyway I had to take an Air Chisel to knock the remainder of the gear off then the chain fell off.
Travis
89 CR500
01 Banshee
