welding truck frame?
seems like i heard somewhere you not soposed to weld vehicle frames. i know your not suposed to weld on heavy machinery frames, theres huge stickers in the cab that says that. but i called a body repair shop and they said they weld frames all the time, after a collision or what not. is it a old myth not to weld a truck frame?
I have cut a few in half and welded them back together. Usually I will cut the frame in a step to provide a little more area to weld. I have also plated them afterwards on occasion, but not every time. Unibody vehicles get sections of the "frame" replaced all the time when involved in accidents. Full frame vehicles sometimes will get one frame rail replaced if the damage is too severe. Or you can just chuck it on a frame machine and pull until the holes line up.
Ins. companies really dont care what the frame looks like, as long as all the mounting points line up and the outside looks good.
In my area, there is more than one long bed converted to a shortbed kicking around. I also have seen some pretty scary looking chop and welds that seemed to hold up fine.
Weld away!
Weld away!
Yeah, or in the case of my '82, the upper front shock mounts...driving around without a front driver side shock is a little weirdExnav wrote:I'll guarantee you that there are a bunch of 73-87 GM 1/2 ton trucks out there that are welded where the steering box bolted to the frame.![]()
Re: welding truck frame?
No its not a myth - Large equipment is made of a type of steel that is heat treated and can be negativly effected (strength) by the extreem heat of welding. Equipment like this have the frame removed and after welding/repairing/streaching/ other should be placed in an autoclave and taken to the correct treatment temp to temper the steel. However - vehicle frames on the normal truck that you see driving down the road are completely different (1/2, 3/4, 1 ton type trucks). Yes they are still heat treated, but the difference in treatment supports welding and customizing as long as it is done correctly. They are designed this was so we can avoid VERY expencive costs when having them fixed after a wreck. Also may of the new frams are stamped double wall steel. Its strong, light, and cheep to make. Welding on this type of frame can damage the double layer so care should be taken not to penetrate both layers. actually its best to bolt to this type of frame and avoid welding. As was said - Step cuts, or cross cut and square plated, work well. If you look up most of the Baja rules they have many very good welding "rules" that should be abided by in every job. But most of all - Call the service department of a dealer or even a body shop and see what they say about your exact vehicle before starting.100hp honda wrote:seems like i heard somewhere you not soposed to weld vehicle frames. i know your not suposed to weld on heavy machinery frames, theres huge stickers in the cab that says that. but i called a body repair shop and they said they weld frames all the time, after a collision or what not. is it a old myth not to weld a truck frame?
To see a truck I made check out - http://www.world4wd.org/PROJECTS.HTM - no thats not me in the picture - thats my Jeep I had to sell when I moved to Washington from New Mexico.
!!OUCH - Being the best is easy when its already in you!!
the reason i brought up welding a frame was this- many years ago when i bought my truck, i didnt notice at the time but later noticed someone had removed the motor, on the passenger side the exhaust manifold and exhaust pipe join right at the frame rail. instead of cutting the exhaust manifold bolt,
the dumb focker that pulled the motor cut a notch out of the top frame rail. about 2 years ago i noticed it had a crack where they cut the frame and the crack was starting vertical down the frame rail. i sent it to a body shop to fix it, but they obviously had their best welder on vacation because when i got it back it looked like a 10yo kid patched up the crack. im going to send it to someone to fix it again, that actually knows how to focking weld
