$2800
Bill of sale (conversion bike - no title. I can put you in touch with George Fannelli at MPS who I bought it from).
2002 CRF450R frame Modified by MPS for a 2001 CR500R engine
Top End has new OEM Honda piston, rings, cylinder, and head w/less than 4 hours
New full Hinson Clutch (plates, springs, dampners, & basket)
VForce 3 reed valve system
BRP triple clamps w/ 20 degree offset
Scotts dampner
ProTaper bars
ARC clutch perch and lever
Forks & shock resprung for 300 lb
DNA Wheels and hubs
Service Honda billet clutch cover
Custom billet ignition cover (1/2 Liter Thumper Eater)
Works Connection glide plate
Works Connection frame guards
Pro Circuit Pipe & Silencer
Throttle Jockey Elsinore kit
Works Connection anodized brake reservoir covers and control clamps
Only problem with the bike is a broke mount point for the radiator shroud on the left that needs to be tacked back on but will require welding aluminum. This is the bottom rear of the 3 mount points and does not affect riding the bike or any functionality. I've taken this in account on the price; these bikes sell for $3500. Service Honda used to produce a similar bike that started at $11.5k https://www.servicehonda.com/afgallery.html
This bike is not a Service Honda
