Anyone out there know where I can get rear shock rebuild parts for a 1983 CR480 rear shock seal ect.
And what shims I should use in the rear shock for the valve stack.
Shock rebuild parts
- Sandblaster
- Last active: November 8th, 2021, 9:19 am
- Sandblaster
- Sandblaster
- Sandblaster
Racetech has it all.
This is their quote:
Shock Oil and Dust Seal Set (set) SSOS 14S $23.99
Shock Shaft Bushing (each) SMSB 1410 $9.99
Bottom-Out Bumper (each) SSBO 144944 $24.99
Reservoir Bladder (each) SSBL 485095 $19.99
Oil $29.99
If you order their gold valve (Which I didn't ask about) they will give you a multitude of shim combo's depending on all your riding factors.
Oil $29.99
