Had some issues with my bike last trip out, was starting OK but blubbering through mid and top end, running like the choke was on, no the choke was not on.
It was fine, running great when I put it away a couple months ago. I pulled the carb off all the jets looked fine, reset the float level but it looked Ok, put everything back and same issue. I ended up pulling the PWK AS off my quad, then it ran great. I suspect that possibly the float is bad, does anyone have the weight that the float should be? I know that with the old brass floats that was how you check to see if they were still good.
PWK float weight?
PWK float weight?
15.8 grams new
