strange fueling issue
ddewey78
Post by ddewey78 »
So I was riding over Thanksgiving and one day my bike was running great, the next it started winding up, as if the fuel was shut off, but it wasn't. If I pulled the choke on, it would idle back down. Any thoughts where to start looking?
FYI it is a 97 motor with a pwk carb.
Air leak.
motardcr500
Post by motardcr500 »
Sounds like a classic air leak.
I'd start with a thorough inspection of the carb and the carb boot.
From there I would do leak down test.
When is the last time the engine was rebuilt?
ddewey78
Post by ddewey78 »
it had a top end put in it last year, maybe 12-15 hours on it. I havent even unloaded it out of the trailer yet, but when i do, i will start with looking at the carb and boot, thanks
motardcr500
Ok, If the carb and boot checks out ok, you might want to toss in some crank seals.
It certainly can't hurt :D
jr475
Post by jr475 »
This happen to mine with about the same amount of hours and it was the base gasket.
ddewey78
Post by ddewey78 »
delayed reply,
so i checked the carb and boot, looked fine, so i broke downand i bought a leakdown tester, glad i did. turned out there was a tiny split in the boot, never would have seen it. fixed it up, and runs great now. thanks!!!
Sandblaster
Post by Sandblaster »
Good to hear.
Love my leak down tester...
