Take a look at these. The piston has 25 on the crown showing overbore. Comments on the piston and cylinder wall if you can see anything. Calling Glen in the morning to get it fixed up.
Crummy pic of the bore.
My real question is about the apparent spider cracks in the next 2 pics around I am guessing crankcase ventilation holes? Ideas and thoughts?
If that is an original 85 cr500 on it's second bore and piston, I'd say it looks very good. Show me any other 23 year old dirt bike that looks that good, gota love the Hondas.
You will not be able to see the bottom of a crack. A test I use in the Jet Engine world to see if something is a stress or a crack:
Use alcohol
Apply liberally to surrounding area and suspected crack
Blow lightly, the alcohol will evaporate quickly
If it is a crack, the alcohol will seep into it keeping it from evaporating. "The crack will stay wet." If everything dries..its a flaw in the metal.
Rosco-Peeko wrote:You will not be able to see the bottom of a crack. A test I use in the Jet Engine world to see if something is a stress or a crack:
Use alcohol
I think those holes are there to direct any gathering oil down to the main bearings.
OR maybe they direct some premix mist up to the piston pin bearing.
I cleaned the bridge with some Brakleen and it feels smooth to the touch, but the wear pattern is irregular. There are shiny metallic areas and parts that are brownish in color, but definitely smooth. There is a corresponding wear pattern on the piston.
Yep...getting it punched, head cleaned up, new wrist pin bearing, piston and rings, and gaskets.
Glen was cracking me up on the phone today. Next year at Sema, I am going to have go and meet him at his booth at the AAPEX show. He's a character for sure.
Have you got it all put back together yet? I'm anxious to hear how it runs now. Does Glen do a general clean up on all the ports, like match the exhaust port to the manfold and touch up the rough transfers?
Not all back together yet....haven't the time to work on it. Call Glen and discuss what you want done and I'm sure he can help steer you the right way. In the short time I have spoken to him, it is quite apparent that he has forgotten more than I will ever know about the CR500 engine. His number is in the approved vendors section.
