Here is another 500 top end on a Honda Pilot, he had a problem with the piston breaking between the ring grooves on the intake side. here is the link to the pilot forum, I noted that the oil holes were not drilled for the exhaust bridge, would that have caused the failure?
http://www.pilotodyssey.com/PO/viewtopi ... =2&t=14552
CR500 topend on FL400 Pilot
I've seen that. Not that its a bridge deal for sure because I've seen it even on a bridgeless one but the top of the boost port will be higher at the outer edges than the center and not have much chamfer. A little snuggle up of that ring end gap never helps but it'll snag the ring land on the port edge and bust it out exactly like pictured.
the boost port has been "ported" with a sanding roll and its left an M shape to it.
