Help!!!!
freeride588
Help!!!!
Post by freeride588 »
Ok so my bike is having some issues.
The crank seal was bad and sucked tranny fluid. I replaced the seal and went through the bike just to make sure. Carb good and jetting was good before this. Reeds look good. New pipe and silencer. Air filter clean. After outting it back together it started right up and was smoking alot. So it continued to heavily smoke and runs but sputters and wont rev out. Let me know what you guys think im at a loss here. Thank you.
Kevin
Tharrell
Post by Tharrell »
Sounds ironically like a bad crank seal :shock:
OUTKAST INC.
Post by OUTKAST INC. »
or bad center gasket
replace the float, unless you just did it, if that dosent fix it it needed to be replaced anyways
freeride588
2strokeforever wrote:replace the float, unless you just did it, if that dosent fix it it needed to be replaced anyways
Carb is new and i checked the float. Good idea though.
Turned out there was just alot of tranny fluid in the crank that needed to be burned out. Ran it for awhile changed the plug and its good.
Kevin
