Have this sitting on my shelf collecting dust. I bought it in hopes of an interesting project, but that never came to light. The bloke who I bought it from did a top end with a 89.5 mm wiseco. The crown of the piston is still clean enough to see the part number with no problem. I'm more than willing to part the engine out to keep others living. The crank seems to be in great shape with no rod play (hard to come by a good rod these days, no?) The cases, while having usual wear, are in fine shape with no damage around the sprocket / clutch actuator. Both standoffs for the guard are in tact.
I went through the carb, cleaned it and fit a new float needle I had as a spare.
84 CR500 engine, carb, ignition and pipe for parts
