My Custom Headstay
lambofgod85
My Custom Headstay
Post by lambofgod85 »
:shock: This is my first design of my Gen3 Aluminium Headstay, It took me all day cause I have never used an CAD drawing program. I think i did alright. All the plates will be waterjet cut out.
What are your throughts of it? :shock: Image[/img]
Image[/img]
I am still designing the CDI and Coil mounts which will sit in the middle of the box section.
look around, make the thing brace to the shock tower area of the frame. 1/3 the weight/material and results in the same hold as every other honda two stroke. its simple and it works. Likely even use the side arms from the 4 stroke motor mounts if you wanted.
Re: My Custom Headstay
lambofgod85 wrote::shock: This is my first design of my Gen3 Aluminium Headstay,
Gen 3 bikes dont need exotic headstays.....
This was for a Gen 4 CRF450 chassis....
i'd do something like this, done it before and its been great. I'm planning the same thing in my gen5
not my picture...
gregrobo
Post by gregrobo »
Roostius_Maximus wrote:i'd do something like this, done it before and its been great. I'm planning the same thing in my gen5
not my picture...
thats the only way to do it the cross brace style is junk you will never stop it vibrating and never keep your engine mounts tight
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
Yup....... OEM
Gravel Scratcher
Post by Gravel Scratcher »
how we did it on my gen5 (450)
billet block welded to frame with oem cr250 headstays
sknh603
Post by sknh603 »
AlisoBob wrote:This was for a Gen 4 CRF450 chassis....
I like your coolant manifold did you make it and are you using a 250 or 125 radiator?
Steve
Bronson
Post by Bronson »
Gravel Scratcher wrote:how we did it on my gen5 (450)
Your coil mount is slick. Gonna try and use that idea on my '04.
2004 CRF450R | KTM 300 XC-W | XR100 minimoto | GSX-R 600 track | VFR800 street
Gravel Scratcher
Thanks mate
Try Roosty, I believe he is knocking up some of these. Simple bolt on that uses standard coil with no modification
Thanks Paul, i have something similar, I mounted the coil bolts 90* to the ones pictured so that the mount can be flipped over and its 5mm offset can hide the coil up higher if required. I've done them for cr5 and cr25 coils
I put my coil 3' away, under the number plate.
No need to muck up the limited room, under the tank.
gen 5 has a mountain of room under the tank, thats what Paul has pictured here and what I did the mount for.
kibler
decomp
Post by kibler »
How do you push the decomp? Burn you hand on the muffler? I know....you have gloves. Maybe it is easier than it looks. Can you hit it when you grab the kick start head?
Kibler.
Nodge
Post by Nodge »
Or you could have it put on the other side,
Hillbilly500
Post by Hillbilly500 »
Here is the one I did on my 02 cr250 swap
Hillbilly500 wrote:Here is the one I did on my 02 cr250 swap
[URL=http://s259.photobucket.com/user/pat4x4 ... 0.jpg.html]
:birthday:
mxdogger
headstay
Post by mxdogger »
That part looks identical to the one's i have made :wink:
