extended shfter?
Kuma
extended shfter?
Post by Kuma »
OK, what do you big guys with big feet do about the shifter, is there any aftermarket units out there? I need about 1 1/2 - 2" longer, ok ok I waiting for the comments :lol: , seriously is there something available?
Thanks,
Kuma
Post by Kuma »
If not, does anyone know if the shift splines on our bikes are the same as any others?
Kuma wrote:If not, does anyone know if the shift splines on our bikes are the same as any others?
I think the 250s fit...
I think the 650 shifter is longer, and the same spline.
I think other brands share the spline too... Kinda like kickers.
Rhino89523
Post by Rhino89523 »
I honestly don't put my foot under there, I catch it with the corner of the sole on my boot. I have a 250 shifter on my bike right now so I know the splines are the same on that. You could buy one of those IMS shifters that are made out of steel and cut/modify as needed.
Kuma
Post by Kuma »
Thanks for the input, this is for the hyprid quad and the foot pegs are farther forward than on the bike.
other
Post by other »
The older XL and XR 600's had the same spline too, and steel levers that are easy to mod. (KLX 650 Kawasaki fits too, but they have the weirdest pressed steel lever . . . ) Also CRF 450 is a bit longer than std 500 lever, but a slightly goofy bend . . . .
Kuma
Post by Kuma »
AlisoBob wrote:I think the 650 shifter is longer, and the same spline.
Bob,
if you're out around your toys, could you possibly do a fit check with the 650 shifter on the 500 engine to see if it clears the case? Going to Glamis weekend of 26th and trying to get things sorted out.
