87 5hundo
Recount your rebuilds here!
02cr250r
87 5hundo
Post by 02cr250r »
Just rebuilt an 87 500. Is ther any way to make a better connection between the pipe and the header/manifold off the motor. Exhaust leaks out frOm that area.
Nodge
Post by Nodge »
Use this stuff:
mr500
Post by mr500 »
This is what I've used,Atomic brand steel manifold.
Just replace the supplied o-rings with nirtrile o-rings and put a fat 0-ring
where the pipe butts up against the manifold to reduce metal on metal contact. No more leaks :D
Keep it real, Keep it steel.
