anyone running a 19 inch rear wheel on their cr500?
I picked up a set of wheels.
Talon hubs, Bucanan spokes and Excel rims.
The rear wheel is a 19 inch with a paddle tire on it. Will the 19 inch wheel pose any problems on the CR5? The diameter with the knobbie tire, i assume, would be the same as the 18 inch wheel.
Looking for advice/opinions.
Thx!
If your going to use the paddle take the flapper off and put a shock cover on.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
- redrocket190
The outside diameter is meant to be the same as an 18". The lower profile of the 19" results in a stiffer side wall and more grip on smoother surfaces. My understanding is the 19" grew out of supercross and then jumped over to mainstream motocross. Desert racers who value the extra flat protection a taller tire gives have stuck with the 18". I can imagine the biggest pain would be more than one set of wheels with different sizes...
...given you don't have to worry about pinch flats in the dunes, maybe the extra stiffness of a 19" carcass will make the paddle tire work better. Just a thought.
Michael Stiles
2007 Honda CR500R-AF
I put a 19" on my '01. Main reason being I used it for motocross as opposed to desert/offroad.
Theoretically you don't need the extra tire depth for sharp object impact protection for moto as opposed to offroad rocks, roots etc.
With the right tire the 19 makes for a lighter overall wheel weight for better suspension action, reduced gyroscopic force and as a result quicker turning/handling...plus they look better in my opinion and give the bike a more updated look.
19" is good for sliding around corners fast
18" gives much better straight line traction, and allows way more control when it gets hairy (sidehill, rocky root hill....)
i really doubt there is much weight diffrence, 1 lb max
better tires available in 18"............IRC M5B
the only place id ever choose a 19" is MX or flattrack
