UknowDamright
Posts: 57 Joined: April 10th, 2010, 5:58 pm Last active:
Post
by UknowDamright » January 9th, 2012, 8:13 am
I found a 06 CRF250 for $750, I am wondering if the stock gas tank will have to be heated and pushed in on the bottom?? I am thinking of buying it.
cmotodad
Posts: 329 Joined: February 8th, 2010, 4:17 pm Last active:
Post
by cmotodad » January 9th, 2012, 9:10 am
If you doing a 500 build, yes it will. We used the shortest plug to make the heating area as small as possible.
UknowDamright
Post
by UknowDamright » January 9th, 2012, 1:14 pm
yeah, doing a conversion....I forgot to mention that, thanks for the info.
One more question, is it a hard process to form the tank?
Mik329
Posts: 493 Joined: October 2nd, 2007, 2:23 pm Last active:
Post
by Mik329 » January 9th, 2012, 2:05 pm
Look at Bob's tank thread. I bought a Chinese tank that fits and does not need to be heated, it only hold just over a gallon though.
cmotodad
Post
by cmotodad » January 9th, 2012, 7:28 pm
We did an Acerbis and a stock tank. The stock tank was more difficult that the Acerbis because the plastic on the stock tank is different than the Acerbis, along with the square edges.
Posts: 4394 Joined: July 4th, 2007, 6:57 pm Last active:
Post
by 100hp honda » January 9th, 2012, 8:49 pm
is it dirt cheap with blown motor ? cr250 is better choice if you dont want to dick with modifying a bunch of stuff
BBA
Posts: 33 Joined: February 3rd, 2012, 5:32 pm Last active:
Post
by BBA » February 13th, 2012, 9:51 pm
post some pics of that if you will. starting a 06 crf250 conversion myself. 97 cr500 motor. i would like to see how it turned out. im gonna do a IMS desert tank for mine....
CR500!
If you understand
Well then
You understand
