Cable operated choke for PJ
Pony
Post by Pony »
Has anyone ever seen a cable operated choke for the stock PJ Carb? I was going to run a bar mounted choke lever on my tracker project. I thought I remembered seeing this setup on Baja 500's for letting off the throttle after long wide open sections. I will eventually step up to a pwk, is there one available for this carb? Thanks guys.
Kuma
Post by Kuma »
not sure if it will adapt, but Honda Pilot (fl400) uses a cable operated choke
So do snowmobiles
there is a PWK version from the sleds, I have a new one I'd dammn near give you if you end up changing to a pwk carb.
The PWK carbs come with a small needle and seat for use with a pulsepump on the sleds so dont just try to throw one on.
Pony
Post by Pony »
well I was pricing pwk's on ebay, is a 39mm the go to size or would a 38mm work? There seems to be a big price difference and I figure its because the 39 is the go to size. JW
39, you gotta watch out for the sizes of the 38, a 38 airstriker has the same size flanges as a 39, but a standard 38pwk is listed as smaller flanges.
