Lazy 96
Lazy 96
I have a 96 500 motor that seems lazy on the bottom. The jetting is very good, starts easy and runs clean. Is there a way to help pick up the bottom and make it smooth at the same time? Anyone with experience on Roosty or Eric Gorr engine mods? Not really wanting to spend a ton of cash at it. Thanks
Without doing the whole engine cases and everything i did a cylinder for AlisoBob, should ask him what he thinks of it, theres definately some guys with Gorr work on here that'll give a review too.
Re: Lazy 96
What pipe are you running?cmotodad wrote:I have a 96 500 motor that seems lazy on the bottom. The jetting is very good, starts easy and runs clean. Is there a way to help pick up the bottom and make it smooth at the same time? Anyone with experience on Roosty or Eric Gorr engine mods? Not really wanting to spend a ton of cash at it. Thanks
I hate the low end pull of a PC pipe. If I wanted to clutch my bike to get it to go I could just ride a 250
When you talk about lazy low end are you talking about at partial throttle settings or hammer down?
with that pipe you will need to touch the clutch to perk it up on corner exit. Gnarly pulls hard much lower rpm. Takes a very fast track to miss the high rpm pull of a PC. I've swapped back and forth a lot. Always end up back on the FMF. If you can get your hands on a fatty you would be quite happy as well. Even a stock pipe would be better than the PC down low.
try diffrent needles, there only $5.05 from sudco, im having good results with a #7 slide and 1370 needle, 39.5 pwkIm having the same issue. Bottom seems a touch burbly, then hits super hard. I am running 1369 needle top clip position, 52 pilot, 170 main.
FMF
My 85 (1997 frame) pulls like jet right off idle - hard to accelerate without pulling up the front end and ripping the back tire off. I have a PJ with low boy Gnarly and 89+ reed cage with super stock reeds. Now that I have a 250 ignition it will perhaps be worst - cannot wait to try this weekend.Mik329 wrote:That's exactly what I used to get when I put a PC pipe on my 85 thru 88 500's so I gave up on them and just stick with FMF. Never tried a PC on my 90's motors.
Steelie Build Done
Re: FMF
I hear ya, I went from a CR250 to a 500 in 1985 and I'd be embarrassed to admit how many back fenders and bars I went through trying to ride that thing wide open like the 250.CR500PHIL wrote:My 85 (1997 frame) pulls like jet right off idle - hard to accelerate without pulling up the front end and ripping the back tire off. I have a PJ with low boy Gnarly and 89+ reed cage with super stock reeds. Now that I have a 250 ignition it will perhaps be worst - cannot wait to try this weekend.Mik329 wrote:That's exactly what I used to get when I put a PC pipe on my 85 thru 88 500's so I gave up on them and just stick with FMF. Never tried a PC on my 90's motors.
