shock lengths/ interchangeable linkages
coley13
Post by coley13 »
I would like to try my ohlins in a gen3. Problem is my shock measures 460mm eye to eye. I'm not sure if I can get a longer clevis. My gen3 is 490mm eye to eye. If anyone has any idea's I'm all ears. I was hoping maybe there an interchangeable linkage from maybe an early model that may suit my needs. Or possibly a clevis to suit. The ohlins clevis is 90mm to the center of the eye with 16mm shaft. I would need 120mm clevis. I've seen some gen3 with ohlins so hopefully some of you guys can chime in.
seanmx57
Post by seanmx57 »
I would contact ohlins about the availability of a different clevis. That's what showa does, same shock different clevis
