cr250 forks?????
freeride588
cr250 forks?????
Post by freeride588 »
I was wondering what i would need to do to put 2002 cr250 forks on my 91. I found a very clean set of forks for cheap and if the swap is possible i will pick them up. Thanks
Kevin
yota
Post by yota »
not sure on the 500 but on my 95 250 steelie I had to use a newer upper clamp and use some paper thin alum to shim the lower clamps and change the brake caliper to a newer one (used an 08 4 stroke one). I think I also had to use a newer front axle as the stock one was too short. forks are 08 CRF250r with Ohlins TTX inserts.
Actually I don't think it would be that great if you kept the stock shock, mine had a good PC revalve and still was not balanced with the new fork. Luckily I found a brand new Ohlins shock made for the 250 steelie for cheap on ebay and together they work great.
09 TTM CR500AF
08 KTM 200 XC
08 Ducati Hypermotard
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
