WTB Hydraulic clutch conversion
- other
To suit 1990 CR500. . . . if these things are worthwhile ? I have several other bikes with Magura hydraulic clutches (570 'Berg, 510 Husky, EC Gasser etc) and all of them have a one-finger light pull, constant bite point and progressive release. That's what I want from the CR, which currently needs almost a full hand pull. (Basket is stock, and barely ribbed on the leading faces, although when it goes into the AF it will get a Hinson or similar)
it dosent give a much lighter pull over a well maintained cable..., the main advantage is no clutch fade, i can use 1 finger, but not all day, note i have popeye forearm muscles
if i were to do it again id call magura directly and get a 9.0 mm master cylinder (cr5 kit comes with a 9.5) to make it 10% lighter
im also using a frequently greased enduro engineering bearing lever, it helps a tiny bit, but now the rollers wore dents in the pin after only 1 season
grease the clutch arm too, it all adds up
also only use magura blood, tried mineral oil but it was too thick making it a bit harder
for bleeding follow bobs procedure, works great if there are any bubles it wont disengage fully
- other
I heard tell that you could use baby oil in 'em too . . . . any truth in this ?
- other
Thanx for your help mate. I guess I'll just have to man up, and get working on my own set of Popeye forearms ! ( I wonder if that old spinach trick actually works . . . . ?)
- Rhino89523
I recently rode a 500 with the hydro clutch and I didn't really like it. It had zero feel for hookup, I stalled it on my first start. My stock clutch, steel plates, stock springs, fresh cable, lubed actuator, good lever....pulls really easy and nice. After riding one with the hydro I have zero desire to own that mod. Just me.
That would have been my bike, and I dislike it too...... and its my bike. Its been on my bike for 6 years now, and 85% of the time I wish it wasent on there.
The cable has WAY better "feel"....
Like Matt said, a well maintained stock setup has a pretty light pull. If its heavy or stiff..... something is wrong.
I think I'm going back to the cable.... soon.
It does give a lighter pull, I've got some serious trouble with my hands, it makes a big difference.
BUT, after 3 rides i took mine off because it faded out and left me without a clutch for a good hour back to the trucks.
I have one i'd sell, pd 150$ for it, thats what i'll take for it. I also have the hotstart clamp piece so i could remotely open my decompressor, add 15$ for that.
I still like mine. It's been on there for several years now. The "feel" was not difficult to get used to.
How does that happen? Not understanding the physics of that at all. Unless you ran the line past the pipe or something.Roostius_Maximus wrote: it faded out and left me without a clutch for a good hour back to the trucks.
slave seal leaks all the oil out and your lever goes floppy///
i use the shit outa mine and havent had any problems yet, other than wearing levers out
had to bleed it a few times
for me it was the best mod i did, i cant deal with clutch fade
if its bled properly i cant tell the diffrence in the "feel"
It got progressivly worse thru the day, worked thru alot of creekcrossings, actually all the creekcrossings til the last one, the tough one
Atleast its hard to stall, in 1st i kicked it and it'd start driving, then just point it at the creek bank and hold it wfo.
- other
Well, opinion certainly seems divided on this. So, as I always do when there is no definitive "this thing is awesome", or "this is a POS", I will make up my own mind on the subject !
Roosty, I'll take that deal, including the remote decomp actuator.
PM me with Paypal details please mate.
Cheers guys.
Gotta say, I'm a bit bewildered about the clutch fade issue. I assume you mean either A] drag, or no clutch actuation at all, which can only come from a leak/loss of fluid, or B] clutch slip, which would have to be a result of fluid expansion due to heating. This is the very problem hydraulics were intended to overcome, being 'self adjusting' by nature . . . . ?
Either way, it would have to be a fault with setup or similar, surely ?
As for feel, I only have 2 (dirt) bikes with cable clutches, the CR500, and a KX450F (yeah, I know, sorry !) and the cluches on both are heavy, grabby, and prone to the bite point moving with temperature, and frankly just suck ! All my hydraulic clutched bikes are faultless and smooth.
Cheers guys.
- other
Brit, you have a bit of a reputation for loving farmyard animals too, so should I trust that recommendation, I wonder . . . . . ? Yeah, OK, I'll go with it !
with a cable if i adjusted my lever with ZERO freeplay when it got hot 220F+ i would have a inch+ freeplay, i could tell how hot i was running by the freeplay in the clutchand prone to the bite point moving with temperature
hydraulic always has 0 freeplay, regardless of temp
thats the main reason im happy with mine at $275
same throw lenth sean, the lever is identical with only the backrest that sits against the stator plate not being on the 250 model
If you're having problems with the Magura, you're doing something wrong.
with mine bled i got the same throw as a cable with 0 freeplay, so when i was riding i had way more throw (or disengagement)keeping a magura disengauging 100% so it doesn't drag when you pull the lever is the problem
look at the slave and press the lever 1/16 of an inch, if the slave dont move proportinate then it aint bled properly
alisobobs bleeding procedure rocks, easy and no air gets in
