Comp Eliminator 1964 Chevy II
1964 Chevy II SS / Modified
Currently runs in SS/CM
- Former Record Holder
- Best Engineered Division 7 LODRS
Car is painted gun metal grey metallic w/ ghosted flames on hood and front fenders
$55,000 turn key
$30,000 less motor, transmission, torque converter
Engine Info:
- 352 CID Chevy bow-tie block w/ 18 degree heads
- Bryant crank
- Billet 55mm cam
- Jesel Belt Drive
- Jesel Lifters
- CP Pistons
- Gregg Davis Intake
- External oil pump
- Moroso oil pan
- GRP rods (new)
- Total Seal Rings (new)
- Everything is fresh off the dyno… 965 hp
Features:
- 4130 Chromoly Roll Cage – Chassis certified to 8.50 (new tag)
- Ed Quay Ford 9” Housing and Frame Rails
- Mark Williams 35 Spline Axles, Spool and Ceenter Section w/ Lamb Components 6.00 gear, pinion support, yoke and housing ends
- 1-3/8 Lamb 4-Link Bars w/ 4130 Chromoly Rod Ends
- Lamb Components Crosslink
- Wheelie Bars with Innovative Racing Components wheelie bars
- Lamb Components Double Adjustable shocks front and rear
- Lamb Components Retro Disc Brakes front and rear
- Lamb Components master cylinder assembly, brake rod retainer and brake pressure gauge
- Weld Alumastar Wheels w/ Phoenix Radial Tires (9 passes) and Hoosier Front runners (3 years)
- Jaz 5 gallon fuel cell w/ Product Engineering 400 combo pump and filter
- (2) Turbo Start 16 Volt batteries
- MDS 7AL3, MSD coil, Crank Trigger and Front Drive Distributor
- Precision Performance Products air shifter w/ CO2 air bottle and ACD digital shift controller
- Racepak V300 w/ (2) Air/Fuel sensors and (2) fuel pressure sensors (Pump and Carb sensors)
- Kirkey Seats w/ grey cloth covers, grey lightweight carpet and door panel, and new glass
- DJ Safety Seat Belts (new)
- Auto Meter Tach, Oil pressure, and water temperature gauges
- 4” Aluminum Driveshaft
- Pro Trans 904 Transmission with a 228 low gear
- A-1 Torque Converter
- Performance Welding 2” step headers
More pictures available on:
www.autoimagery.com search “Gary Tackett”
http://www.bobjohnsonphotography.com/
Seller Phone Number: 714-920-2963
I can vouch for this car, its perfect. I cant even pick it apart.
$55k is a STEAL!!!!
Super Stockers are cool. :cool:
Wow, just looked.. The index is 9.50 for SS/Cmod
Nice
Re: Comp Eliminator 1964 Chevy II
AlisoBob wrote: $55k is a STEAL!!!!
:wrongforum: most us can barely afford new handle bars :roll:
100hp honda wrote: :wrongforum: most us can barely afford new handle bars :roll:
I cant help it if your a high school drop out K/C.
$55k is still a steal. Cheaper than 4 S/H's.
some interesting stuff :lol:
352cid/965hp = 2.7 hp per cubic inch
calvins cub motors (25cid) do about 4 hp per cubic inch :wink:
just sayin :D
