My 1997 cr500 restoration!
Recount your rebuilds here!
addski72
Post by addski72 »
Hi guys im just the process of restoring my dads 97'cr500, its been stuck in a shed for 10 years!.
basically my rmz died, and was stuck without a bike , so i dug out my dads old 500 rode it AND loved it like nothing i had rode before. sold the rmz and the restore began!
So far = replaced every bearing in engine+seals.
barrel honed to 90.00mm exhaust bridge reduced.
wiseco piston kit.
frame powder coated ferrari red.
new nuclear red plastics
1989 rad decals
1988 swining ard decals
renthal fat bars and clamps
lots of other little bits.
gonna put pics where i am so far, picking up frame tuesday, and finishing engine monday, then will put up the next lot of pics.
[/img]
addski72
Post by addski72 »
sweet :cool: . :headbang: did you leave the mud on for 10 years ?
exh bridge reduced ? hope you didnt meen thin it.
addski72
Post by addski72 »
lol no :D . the mud was from a very muddy dirt mx practise day, few days before i striped it.
And as for the exhust port bridge, had a couple thou taken away from where it meets cylinder, where wiseco ask u to drill holes in there pistons, witch im doing monday.
ok your just relieving the clearance against the piston :cool: . thought you meant thin it side to side, which aint a good idea
addski72 wrote:Image
SEXY!!!
Gmbond
Post by Gmbond »
It's like spotting the cr500 in it's natural habitat!
addski72
Post by addski72 »
Hi guys. thanks for the replies , i was just wondering what you guys thought of wiesco piston?? as i have all the bottom end of engine built now, and i will be drilling and installing the wiesco top-end 2moro.
The bike will be used for mx practise/open class events. and w-s-m beach race.
I could get my hands on a new cast piston if i must. but i guessed forged wiseco would live longer.
P.S. the bike is a 1997, just it had the black&red saddle, and the black rad scoops stolen when the bike was chained up, just before it got stored forc10 years.
Tharrell
Post by Tharrell »
Somebody stole your rad plastic?
You got mexicans over there too huh?
addski72
Post by addski72 »
The bike was chained up very well, they couldnt get the bike, so they took the plastics and seat.
gregrobo
Post by gregrobo »
nice bike. whats the yellow wire for?
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
addski72
Post by addski72 »
Hi m8, the yellow wire is to a extra coil on the stator. the bike is road registered, and it had road tyres and lights and a number plate when i got it out. i put it back to mx trim.
Why is the case all goofy around the shifter shaft hole?
addski72
Post by addski72 »
im guessing the bike had a big fall on the gear shaft, cause when i took it apart, there was a crack in the inside lip where the shaft goes through. the guy i had weld thought it was a good ideal to back fill the corner with weld (prick).
Well i done a dummy build, and the weld was fouling a selector fork. So borrowed a dremel and cleaned it all up.
addski72
Post by addski72 »
belive i was not very happy when i saw the weld work! from a "professional welder" :twisted:
http://www.millarengines.com
Roosty's brother Luke is the Tig-Master....
addski72
Post by addski72 »
im in the uk bud :D
thanks tho
racein01
Post by racein01 »
Welcome...looks like a good project.
There aint much trailer under that bike.
blownbillybob
Post by blownbillybob »
[quote="AlisoBob"]Image
I had one on the right side case that had a crack and the shaft hole was oblonged I bored it and made a little sleeve for it and pressed it in then had it welded worked good so far
00'cr500 trailclimber
93'cr500 beater
92'cr500 hillclimber
89'cr 500 bent frame
04'crf230(wifeys)
02' cr125(sons)
02'sx65(sons)
03'xr50(sons)
addski72
Post by addski72 »
Hi guys heres the next lot of pics! she's nearly finished now , just want to check how the carb is jetted 2moro. Then finish her off! and make a youtube vid of first start that ill post.
addski72
Post by addski72 »
addski72
Post by addski72 »
hi guys she is all finished now, here is a vid off the first start. srry its dark but got it finished alittle late.
http://www.youtube.com/watch?v=4x4HZS_mzpA
ill put up a picture in 5mins.
ps i know the white tank looks out of place, gonna red tank or red gfx. havent decided witch yet.
I like the white tank....
addski72
Post by addski72 »
here she is.... have the foot pegs to put on powder coated black, and black gripper seat cover to fit.
matt_NC
Post by matt_NC »
Nice job!!!
The powder coating on the frame is such a close match to the plastic.
It looks very factory :cool:
