'I looked in the mirror and I couldn't see anything': Tornado pilot tells of moment navigator fell out of 450mph planeBy Andrew Levy
Last updated at 5:19 PM on 20th October 2010
Killed: Civilian navigator Mike Harland fell from an RAF Tornado
A pilot described yesterday how he gave a thumbs up sign to indicate he was okay after a cockpit explosion in an RAF Tornado, unaware his navigator was plunging nearly 6,000ft to his death.
Mark Williams, 50, had turned the fighter upside down during a test flight when he heard a deep 'thump' noise and the plane filled with debris.
Unknown to him, the rear seat had fallen out and crashed through a hole in the canopy with Mike Harland, 44, strapped inside. A locking pin on the seat had not been secured properly.
The tragedy happened as the two men, both civilian employees of defence firm BAE Systems, were on a 90-minute test flight from RAF Marham in Norfolk after the plane had been serviced.
Mr Williams told an inquest he was performing a 'negative G check', where the plane is flipped upside down to check for loose objects, but turned it upright immediately after the explosion.
He added: 'I thought Mike would be able to see me and I put my thumb up to him... to show I was still here and could fly the aircraft.
'I couldn't talk to him because the noise was so loud. I couldn't hear my own voice.
'I realised my part of the canopy was still there. I realised that the environment in the rear cockpit was likely to be not nice.'
The fighter had been travelling at 450mph when Mr Williams heard a loud explosion behind him.
'It was like a thunderflash or a massive firework at a display - a deep thump noise,' he said.
A Tornado fighter jet like the one navigator Mr Harland was ejected from during a test flight
'Immediately the area in the cockpit began to mist up as the air inside condensed. When I opened my eyes I saw the mist was full of yellow debris like loft insulation and other bits of paper and stuff as well.'
He told the hearing in Norwich he eased back on the throttle and applied the airbrakes while he waited for the debris to clear.
BAE systems test pilot Mark Williams who was flying the Tornado GR4 when navigator Mike Harland fell from to his death
'I then looked in the mirror and could see nothing,' he added. 'I could see right the way back to the rear bulkhead. Normally I would see the navigator and ejection seat.'
The pilot, from Grantham, Lincolnshire, said he at first thought his colleague had ejected but realised this wasn't possible because the rocket powered ejector seat had not been activated.
There was no sign of a parachute and he radioed a Mayday to base.
'The obvious conclusion was that the seat had simply fallen out of the aircraft and that is what I told the radio controller,' he said.
The inquest, which began on Monday, has heard how the two men were testing the Tornado on November 14, 2007.
When former RAF pilot Mr Harland's seat began to move during the 'inverted roll' manoevre, it triggered an explosive mechanism which blew off part of the cockpit canopy.
Because the full ejection system had not been activated, the seat was not thrown completely clear and the Gulf War veteran's head was struck by the tail of the jet.
The seat's parachute system failed to deploy for the same reason and it fell to the ground with the married father of two, from Colsterworth, near Grantham, strapped to it.
He was found dead on the ground 45 minutes later. A post mortem revealed he died of multiple injuries.
An officer from Norfolk Police has told the inquest an investigation had focused on how the ejector seat had been refitted after the major service in which the plane was taken apart and reassembled.
Three RAF personnel were interviewed under caution and a file was sent to the Crown Prosecution Service but it was decided there was 'insufficient evidence' to charge anyone with manslaughter due to gross negligence.
An RAF Board of Inquiry into the accident - which was released this week and uncovered shortcomings in the training of air and ground crew - concluded it was caused by the locking mechanism being wrongly fitted during the service.
Mr Williams, who flew back to base after the accident, told the hearing yesterday pilots and navigators were expected to check the locking mechanism in pre-flight checks.
He said he understood it was only necessary to ensure a spigot was correctly aligned in the device, called a top latch plunger.
But the inquest was told crews should carry out a second check to ensure the end of the plunger is flush with its housing to indicate it is properly installed.
Mr Williams said he had checked with 40 other civilian and military Tornado crew and just two were aware of the second check.
HOLY SHIT!!!!
The report said his ejection seat had not actually been activated but "fell" and he hit his head on the tail section so, any possibility of a manual deployment if possible would have been lost.
I imagine, it all happened so fast he probably didn't know what was happening and hopefully he was already dead or at least unconscious while falling. What a terrible story.
