blownbillybob wrote:Cyl. finish looks a little rough....
A little?
Roostys work
Click a photo to change it!
What I actually said was:Dogger wrote on ATM
Projected spark plug used to raise comp.
NGK BP8EVWhat ia the plug #?
dogger315 wrote:What I actually said was:Dogger wrote on ATM
The base of the cylinder head was also machined and a projected
nose spark plug is used to raise compression.
I should have posted the build series here first so you guys could
catch all the editorial mistakes I made - Looks like you're already
well on your way to accomplishing that.![]()
It should read as: The base of the cylinder head was machined to
raise the compression and a projected nose spark plug is used.
I will make the appropriate correction on the ATM post.
dogger
Roostius_Maximus wrote:ya, idea is that the mixture is deflecting off the dome before it reaches the plug.
Ahh, hows the butt dyno work? Does it even show any improvement? Im a total newb when in comes to the 2stroke combustion chamber, but it seems like there would be a ton of other variables.Roostius_Maximus wrote:it means that gorr figures the fuel is deflecting off the head and away from where the plug is located stock, so he uses a longer plug to reach to where he figures its working best
